Que es ese codigo c26 alguien me podria decir
SOURCE: help
C26 is a peak detection error (when the copier scans the white reference plate there is an error in the detection)
The most common cause of C26 error is the
failure the lens unit which is Toshiba's part number 6LA02100000.
The components that fail on the board are IC1
and IC10.
The board can be repaired, but most commonly it is replaced.
SOURCE: erro code c26
C26 indicates Peak Detection Error.
U need to check whether the lamp light on when u ON the machine.
If no, u need to check the inverter cable, inverter board, or exposure lamp.
If light is ON, then u need to perform following:
1. Check if the connectors on the CCD and SLG boards are disconnected.
2. Check if the shading correction plate is dirty.
3. Check if the conductor pattern on the CCD board is short- or open-circuited.
4. Check if the conductor pattern on the SLG board is short- or open-circuited.
5. Replace the lens unit.
6. Replace the SLG board.
SOURCE: Toshiba E-Studio 810 says call for service when
check to see if lamp lights. if not, replace lamp.
if lamp lights, pull the platen glass and replace the scanner board under cover by lens.
SOURCE: call for service c26 in toshiba copier e 810
C26 indicates Peak detection error.
U need to make sure the exposure lamp is light when u switch ON machine.
If no light, then u need to check the inverter and the exposure lamp.
SOURCE: What is the solution for error code c26 on my
Hi how are you i hope you are well this is jack ..my personal ID.. ([email protected])
C26 Error is scanner error
please check the scanner unite
1 scanner lamps.
2 scanner strip.
3 scanner bord
4 LGC bord.
please check these all goods are working properly.
Thanks
Best Regards,
