My wii console give me this site and activation code to activate youtube
SOURCE: Turn off wii balance board
With our board it goes off just fine leaving it alone, maybe something is stuck on it try removing the 4 bottom legs covers and just leave it be a few minutes if that dont work just take the batteries out and find a safe place to keep them for future use. Find out if your board is under warranty and return/exchange it?
They are sensitive so just be patient :P
SOURCE: making connection between WII and internet and Netflix
Sounds like a netflix issue.Contact them with any information you have from them.Here is the link.
http://www.netflix.com/HowItWorks
SOURCE: trying to activate the wii
Error Code 51330, 51331, and 51332
It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console
-- Basically go back in and make sure you entered the wifi security key (WEP/WPA) properly.
Thanks!
SOURCE: i am not ble to find my wii points card but i have
If you have the receipt I believe it is possible to call Nintendo, or whomever you should call, and tell them the serial number from the receipt.
The receipt should have the number of the card on it.
SOURCE: where's the activation code on nintendo wii?
How to get Netflix to work on a Wii
1.) turn on your wii
2.) press "A" (or any button to get to the wii menu)
3.) on the Wii menu, go to the bottom-left of the screen
4.) click "A" on the word "Wii" (when you highlight it, it should say "Wii Options")
5.) then click on "Wii Settings"
6.) on the contoller, hit the "+" button then click on "internet"
7.) then click on "connection settings"
8.) click on any connection setting (i just use the the one that says "connection 1")
9.) if you want to connect through a wireless connection, click on wireless connection (this will search for WiFi around you.)
10.) then go to "search for an Access Point"
it should find some access points, if it doesn't, then you'll need to buy a Nintendo WiFi thing (i'm sorry, i forgot the correct name for it)
11.) click "OK"
12.) click on an access point with a lock that's unlocked, or click on one with a yellow lock and put a password. if you see a red lock, you cannot connect to that access point.
13.) it will ask you if you want to save the settings. click "OK"
14.) then click "OK" again, to do a connection test (this could take about 30 seconds)
15.) UPDATE THE WII
16.) after that go back to the Wii menu by clicking "Back" until you reach the Wii menu
17.) then click on the wii shop channel.
18.) then click on start shopping
19.) then click on channels
20.) then click on netflix
21.) wait for it to download
22.) then go back to the wii menu
23.) then load up the netflix channel
24.) they're going to give you a password, go on a computer and (if you have a netflix account) go to www.netflix.com/activate or http://www.netflix.com/NRD/Wii?mkwid=s0BEmMX1Q&mqso=80025460
25.) then loggin and type in the code from the wii into your accound
...Now you can watch Tv or movies on your Nintendo Wii
