The mower dies when ever you hit taller grass and the engine needs primed to start again. I am thinking the spring is the wrong one and is not holding enough tension on the throttle.
Have you changed springs? Likely the correct components are there unless you have changed it. Does it run properly and at correct rpm when not in tall grass? Check for proper throttle adjustment first. also check for obstructions (packed grass for instance) under the deck that could be impeding the blade. Lastly, if you have the discharge blocked with a mulch plug, remove the plug. let the tall grass discharge. then run over it again and mulch it.
SOURCE: Troy bilt lawn mower. Will not engage self propell, front wheels
Hello:
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
SOURCE: 6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
SOURCE: My Troy Bilt self propelled mower won't crank or
just tighten the adjustment screw after you push the throttle all the way down...good luck
SOURCE: where is the oil plug located on a troy bilt mower?
Tilt it over so the oil cap is on the bottom...it'll rest on the handle and hang there...put a container under the oil fill pipe...something shallow like a glad sandwich container works perfect...get a paper towel, and reach under an unscrew the cap...all the oil runs out into the container...it'll fit !!
Wipe the dipstick off clean, and put it aside...take this time to look at your blade on the other side...it "should look" similar to wood chisel at the last 5 inches of the blade on both ends followed by a wing under it...BTW: their $12 bucks new...and worth it !!
Go back and look at the container and be sure the oil is finished draining...take the lid for the container and snap it on and move it out of the way (no body likes an oil spill)...wipe off the oil fill spout, and re-fill...takes about a half a quart, so don't over fill it !!!
your done...
