Question about Pentax K200D 10 Megapixel Digital SLR Camera Digital Camera With Shake Reduction 18-55MM F/3.5-5.6 Lens and 50-200M
Hello, I continue to get a "batteries depleted": message after a few minutes even after I install new AA lithium batteries. Can you suggest anything to assist me?
My SB 700 shows temperature after few shuts and when it's twisted
From the SB 700 manual page b8:
v Notes on continuous fl ash photography • To prevent the SB-700 from overheating, allow it to cool down for at least 10 minutes after 15 times of continuous firing. • When continuous flash firing is repeated in quick succession, the internal safety function adjusts the recycling time by up to 15 seconds. If flash firing continues, the thermal cut-out indicator appears on the LCD and all operations are suspended. (0E-31) Allow it to cool down for several minutes to disable this function. • The conditions under which the internal safety function is activated differ depending on the temperature and the SB-700 flash output level. Operation B B-8 Slide the battery chamber cover open while pressing the battery chamber cover lock release. Insert the batteries following the [+] and [-] marks. Close the battery chamber cover. STEP 1 Inserting the batteries Operation B B-9 1.5 V alkaline AA battery 1.5 V lithium AA battery Rechargeable 1.2 V NiMH AA battery Suitable batteries When replacing batteries, use four fresh AA-type batteries of the same brand from any of the following types: • For minimum recycling time and number of flashes for each battery type, refer to "Specifications." (0H-27) • Alkaline battery performance may vary greatly depending on the manufacturer. • 1.5 V carbon-zinc AA batteries are not recommended. v Additional precautions regarding batteries • Read and follow battery warnings and cautions (0A-19 - A-22). • Be sure to read and follow the warnings for the battery on the section, "Notes on Batteries" (0H-9), before using the battery. • The recycling time can be longer when lithium AA batteries are used because they incorporate a function that suppresses the output current when heat is generated in the batteries.
Nov 26, 2015 | Cameras
Hi, Have K200D and in the past few months am having problems with batteries....have always used energiser lithiums successfully but now it keeps bringing up the battery depleted message. If I switch off...
Before you do anything just make sure that the battery you use is a hot one. Then also check to see if you can reset the camera software to factory defaults - you may have to contact mfg for this. If no positive results you may have to resort to repair provided it is cost effective - may not be.
Sep 22, 2017 | Pentax K200D Digital Camera with 18-55mm...
I have a Coolpix L100. On 27 December 2010 after taking a few shots with flash, using rechargable batteries for one year, it displayed in Hungarian that the batteries are depleted, but after I have...
You will have to contact Nikon about any warranty claims. The standard warranty seems to be 1 year.
I have found that there is a firmware update for this camera that allows for support for Ni-MH rechargeable batteries (the original firmware only supported alkaline or lithium batteries). Try that firmware update to see if it resolves your issue.
Dec 27, 2010 | Nikon COOLPIX L100 Digital Camera
I have the Nikon Coolpix L100 camera and have had it for several months without encountering a single problem. I got a message saying that the batteries were exhausted and it shut down. I replaced the...
I have the same problem with my Coolpix L100. On 27 December 2010 after taking a few shots with flash, using rechargable batteries for one year, it displayed in Hungarian that the batteries are depleted, but after I have recharged them, the camera did not start again anymore, displaying in continue that the batteries are depleted, and it turn off itself after a few seconds. I think that the problem is with the sensor of the camera that should measure the battery status, because even if I had new batteries it desplayed an icon with half battery but I never let it depleted totally so far. Now I am wondering if NIKON will offer free service for it as I have bought it just about 16 months ago in the Romanian DOMO market chain.
Dec 25, 2010 | Nikon COOLPIX L100 Digital Camera
Camera consistently says "battery empty"....will not hold for more than a few minutes...yes I have tried new batteries!
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
The above is service and repair information for your camera.
Even, the manual says that you can use alkaline, NiMH, or Oxyride batteries. which are generally 1.25V for each AA, try the Lithium batteries which are 1.5V. They might work in your camera if your camera has some characteristic where the voltage falls below a certain limit and the 'battery empty' message shows up.
They are more expensive, but might solve your problem, even though the manual says that Lithium batteries are not to be used (in a new properly functioning camera)
Jul 22, 2010 | Olympus FE-310 Digital Camera
Camera optio e40 pentax shows the battery life as depleted even tho they are new batteries I have tried any new AA batteries 1.5 then I tried rechargagles at 1.2 for digital cameras.
this is not malfunction.
According to its manual, just turn it off ,wait for one minute and
turn it on again. It'll reset th camera. You need to reset the date/time.
Dec 25, 2009 | Pentax Optio E40 Digital Camera
Installed new batteries and the camera will not turn on. The camera has been sitting up for 6 mo. with no use. We used energizer lithium batteries.
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
You can even contact Kodak direct and they will send you a free CRV3 battery to test with.
(http://graphics.kodak.com/docimaging/US/en/Landing_Page/ServiceSupportContacts/index.htm)
Oct 26, 2009 | Kodak EasyShare C653 Digital Camera
I keep getting a battery depleted message
I don't know but that would be wierd if this was Paula Meadows from McAlester
Sep 08, 2009 | Pentax K100D Digital Camera
Battteries depleted messageon Pentax Espio E40, even though have tried brand new batteries.
HI. this seems to be a battery scanning fault in the programming. try to reset the board by pulling the battery and removing all power of 30 minutes. completely drain all power from this unit for 30 minutes. if this message continues after you have rest the programming, this will confirm a serious fault within the internal program. you will have to send this device back to a pentax repair terminal for reprogramming.
May 22, 2009 | Pentax Optio E40 Digital Camera
*istD Problem with Vertical Grip
Digital cameras require a large 'surge' of power when performing things like processing an image and saving it to the memory card. Alkaline batteries work best when used in a device that draws power at a steady rate. They do not work as well when asked to provide a surge of power. Your batteries are indeed not dead, but they are sufficiently depleted that they can no longer provide that surge that the camera requires. Take them out and put them in something like a TV remote or a radio. They probably have quite a bit of life left. NiHM and Lithium based batteries are much better at being able to provide the amount of current needed right up until they go dead. The 100 shots you got out of your Alkalines is at the high end of what you can typically with Alkalines in your camera. The continuous shooting could be a symptom of the batteries getting low. Another option to those previously listed are AA Lithium batteries which are cheaper than CR-V3's and last nearly as long. They are not rechargeable though.
Sep 08, 2005 | Pentax *ist D Digital Camera
Pentax K200D 10 Megapixel Digital SLR Camera Digital Camera With Shake Reduction 18-55MM F/3.5-5.6 Lens and 50-200M Logo
169 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
