SOURCE: light on my samsung digtal camera charger is flashing orange and
pls checck the batt it is not taking the charge they are weaken and old pls ccheck it
pls rate me fixya for this if u like
SOURCE: samsung nv3 camera not charging
take out the batter and clean the copper terminals with a sharp knife, plug into the charger if still not working leave for 30 seconds and re-try, it took me four attempts.
SOURCE: camera not charging
i got the same problem...it means battery is somehow discharging instead of charging..better get an external charger and remove battery from camera after every use.
SOURCE: I have a Samsung P800
Ok. I have the samsung l200 but the cameras are very similar. I had
the issue as well. When I plug it in it flashes red once, green once,
then orange consistently. It would not charge the battery.
The fix was really quite unexpected. I did two things not sure which fixed it.
1. slide the cable into the camera slowly until the light turned red once, then pulled it gently in and out a few times.
2. as i plugged it in, I tried to angle the plug side to side sliding
it to the left and right on a diagonal. I was hoping the pins would be
touched differently when I did this which might reset something.
not sure which of these two things corrected the problem, but the camera is now charging.
SOURCE: Samsung L830 camera. I try charging it but the
Try another SAMSUNG L830 Battery to see is it anything wrong with the battery or charger, and get a new one.
