LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
A
Anonymous Posted on May 28, 2014
Unlock when door is closed - LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
2answers
2010 express van
The BCM - body control module is what controls the power lock's , disconnecting power can cause some functions to need resetting .
Have the BCM checked for DTC'S - diagnostic trouble code's , that would be my first step . Do you know what wiring diagrams are an how to read them ? Free wiring diagrams here
http://www.bbbind.com/free-tsb Enter vehicle info. Year , make , model an engine size . Under system click on body & accessories , then under subsystem click on power lock's .
Battery Disconnect or Replacement Problems
Driver Door Unlock Operation
When any of the door lock switches are placed in the unlock position, a ground signal is applied to the BCM through the door unlock signal circuit. Upon receiveing this signal, the BCM grounds the control side of the driver door unlock relay through the driver door unlock relay control circuit. Since the other side of the driver door unlock relay winding is connected to battery voltage, the relay is energized. This causes the contacts to close and complete the path from the DRV LKS fuse through the battery voltage circuit. Voltage is then applied to the unlock side of the driver door lock actuator through the driver door lock actuator unlock control circuit. Since the other side of the the driver door lock actuator is connected to the normally closed contacts of the door lock relay to ground, the driver door unlocks.
The driver door unlock function can also be accomplished by the BCM supplying ground to the driver door unlock relay control circuit by either of the following:
• A keyless entry unlock transmission
• A lock out prevention function
DTC B3130 00: All Door Unlock Circuit
DTC B3135 00: All Door Lock Circuit
Circuit/System Description
When any of the door lock switches are placed in the lock position, a ground signal is applied to the BCM through the door lock signal circuit. Upon receiving this signal, the BCM grounds the control side of the door lock relay through the door lock relay control circuit. Since the other side of the door lock relay coil is connected to battery voltage, the relay is energized. This causes the contacts to close and complete the path from the battery voltage circuit. Voltage is then applied to the lock side of the door lock actuators through the door lock actuator lock circuits. Since the other side of the all the door lock actuators are connected to the normally closed contacts of their respective unlock relays to ground, the doors lock.
I have a 95 saturn 2 door, the passenger door is stuck closed. The power lock triggers but still wont open from inside or out. Please help!!!
This usually works.
Take a rubber hammer,roll down the window,then manually unlock the door using the inside unlock button (not the power lock button) while you give the door a good whack about half way down where the door lock assembly holds the door closed to the car body.It may take a few whacks and a few lock/unlock cycles but this usually allows the lock to release and you can open the door.NOW.....take off the door panel and lube that lock assembly and don't close the door unless the lock can be locked and UNLOCKED.
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Programming key sienna 2006 tk
Here are the instructions per the factory manual.
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Insert the key into ignition and leave it in ignition.
D. Close the drivers door.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Feb 05, 2011 • GPS
4helpful
2answers
The driver side door does not unlock - can only (central locking)
Hi:
It is extremely difficult to remove the door panel with the door closed. You mentioned that you can unlock the door with a key, so does the door still open and close once unlocked? You most likely just need to replace the power door lock solenoid, as when they fail, they usually sieze up, and make manual lock unlocking difficult.
A friend of mine has a Lexus 1997 ES and his remote control needs reprogramming. How do I do it for him. Thank you so much.
1. Driver's doo opend and unlocked, all other doors closed and locked
2. Inser Your key in ignition, don not turn, remove key
3. using the manual lock/unlock button on ther dirvers door, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times)
4. Shut door
5 Open door
6. Using the lock/unlock button on the direvers door, slowly press and unlock 5 times (count the lock 5 times and the unlock 5 times)
7. With the door open insert you key into the ignition, turn to ON position (don't start), wait 5 seconds. Trun off and remove key.
8. Locks should cycle once (Car will lock and unlock once). If they don't cycle or they cycle more that once, do stips 1-7 over.
9. Using the remote, push lock button, hold for 1 second, release. The locks should cycle once. If not start over and go slower.
10 Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors shoud unlock.
I got this from a site called FixYa (don't have URL). It took me a few tries but it worked like a charm.
I need programming instructions for a 2002 toyota highlander for my remote.
not accepted.
3helpful
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Need the steps to programme the remote
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second,
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
