There should be a button on the DVD/CD drive itself, just push that small button and the tray should eject. If you can't fine the button double click on "Computer" or "My Computer" highlight the DVD/CD in the list, right click on the DVD/CD and select "eject" from the list. The tray should now eject.
CD Stuck in Device First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
If the keyboard has a CD/DVD Eject key, press it. The
Eject
key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
Double-click
My Computer
Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
If the CD or DVD drive door button is a long clear plastic bar on the
front of the PC, press firmly on the right side of bar. Some models
have a button on the front panel of the PC to the right of the hinged
door. Press the button to eject the drive.
If the drive door button is part of the PC case and is covering the
actual drive door, open the door that is part of the PC case and press
the Eject
button on the faceplate of the drive.
Restart the PC and press the
Eject
button on the front of the drive when the first screen appears (before
Windows launches). If the drive door opens this way but does not open
in Windows, another software program is taking control of the CD
driver. Try shutting down or configuring any software programs that
create discs or monitor the CD or DVD drive.
If the door still does not open, do the following:
Close all programs and shut down the PC.
Unplug the power cord from the power outlet.
Look for the small hole on the faceplate of the CD or DVD drive. This
is the manual release. The location of the manual release hole will vary
Straighten the paperclip and insert it into the manual release hole until resistance is felt.
Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
Remove the paper clip and gently pull out the drawer until the disc is accessible.
Remove the CD and turn on the PC.
If the tray still does not open, do the following steps to check the
power cable for the drive. Work on a hard flat surface over a
non-carpeted floor:
Turn off the PC.
Unplug all power cords from the back of the PC.
Press and release the
Power
button on the front of the computer.
Remove the side panel.
Unplug the power cable and wait five seconds.
Find
a different power cable that is not being used, plug the different
power cable into the back of the drive, making sure that it fits firmly
into the socket. If a different power cable is not available, replug
the original power cable into the back of the drive, making sure that
it fits firmly into the socket.
Replace the side panel and plug in the power cord.
Turn on the PC and press the eject button on the front of the drive.
If
the optical drive does not have the manual eject feature and the CD
tray will not open by using the steps in this document or if a disc has
shattered inside the drive, the CD, CDRW, DVD drive may need to be
replaced.
