The handle fell off on the toilet and won't stay on. Is their an insert that my room mate lost.
You need to replace the handle. Most single-flush toilets have a handle that covers a plastic piece that includes a stem that goes through the bowl. The stem is functions as a bolt held by a plastic nut on the inside of the bowl. When the handle falls off, that stem has broken. If the bowl lid is accessible, you can remove the lid and use the chain to flush the toilet. Dual flush toilets also have a plastic stem or tube that goes through the bowl.
Depending on your toilet, a universal toilet lever replacement may work. These are available at most hardware stores for under $10. For some brands, you may need a brand-specific lever. In a few cases, the part may not be available at hardware centers but is available through plumbing suppliers, plumbers or the manufacturer.
I hope this helps.
(Note: the nut inside the toilet bowl uses a left-handed thread. This is the only case in plumbing where it's lefty to tighten and righty to loosen.)
