your micro cruzer sandisk can perform lots of function .
You can copy your data,songs, video files on your flash drive to use it any time any where .You can do this by just following the simple steps :
1. Plug the USB flash drive to a USB port.
2. A USB flash drive icon will appear on the desktop
3. Double-click on your Cruzer USB flash drive.
4. Select the
files or
folders you want to copy to the USB drive by clicking on them.
5. Drag and drop the selected
files or
folders to the USB flash drive icon.
Note : Do not immediately remove your drive from the USB port,right click on drive icon in notification area then click on safely remove the drive ,then remove your drive from your computer.
2: You can take backup of your computer on your flash drive
3.You can also boot from your drive if *********** board support boot from from your flash drive.
my sandisk is not being read after being bent a little while in the computer. Nothing is being read now when i plug it in
I too have the same prob...however in my case, I neither bent it nor dropped it. The only thing that happened was that I soon as I downloaded something from the disk into the computer, I removed it and remembered that I had to download it to another file so I re-inserted from then on, it refuse to work. It would only lit up for about a sec and then nothing. My computer is not able to read as if it wasn't even there.
Is there anyone outthere who can possibly help us? I have certain vital info that I need from it. Please? Thank you.
[email protected]
