First step is to unplug the 120 vac power for a few minutes to clear any corrupted data that may be present in the controller circuits.
If a "power" reset doesn't help and the lamp or bulb is installed correctly, you most likely have a failed replacement bulb. The symptoms are all standard indications of a failed bulb.
Reduced lamp life can be caused by:
- Lightning and other 120 vac power bumps.
- Collisions with vacuum cleaners or other incidental impacts while the TV bulb is operating.
- Starting the TV without a complete cool down. Bulb will consume a small amount of mercury with each start. Excessive consumption occurs when bulb is "Hot" and turned on.
- Wrong bulb installed as replacement.(Philips original replaced with Osram or El Cheapo)
- Poor quality or damaged bulb installed as replacement.
- Bulb damaged during replacement
- Bulb installed incorrectly at replacement.
Almost all Hitachi 55vs69 "No Picture" failures are related to the bulb.
Many of our service events are with customers that purchased El Cheapo bulbs from "shopping cart" websites or picked up a bulb from a small "local" TV shop. Many small shops stock of 3 or 4 bulbs and try to substitute or cross reference to fit more than 200 models of TVs from 7 different manufacturers. If a premature bulb failure occurs, they have the opportunity to sell you some expensive service.
Go here to see all of the different Hitachi TV bulbs that are available in Canada.
Find Your LampUse the correct bulb for your model and if you are uncomfortable with the replacement procedure, get local service.
