Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
013/ 054/ 055/ 060/ 065/
067/ 089 These are the three digit codes to Jvc brand TVs. As there is no remote control with you, the first thing to know is, to which code do your TV respond. Some TVs will respond to three digit codes, some others will only respond to four or five digit codes. If your TV do respond to three digit codes, a universal remote control, which have the above said codes in its code list will work. If you wish to get three, four & five digit code list to some popular remote controls, check the links given above. You can choose the proper remote control to your TV. But before buying a new remote control, make sure about the number of digits of codes that TV must have.
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
As far as I can remember, the original JVC remote doesn't support a DVD player. It doesn't have the necessary buttons to control the player functions. You'll need to stick with the original Apex remote if you have it, or look for a universal remote that is compatible.
Unfortunately, you need to have the original remote control to turn off parental control lock.You need to use original remote control to access menu and then turn off the control lock.There is no alternate way.If the remote is not working, you need to buy a used / new remote.You could buy it from :-
These are the steps on how to program your Universal Remote Control to your JVC TV even without the list of code.
1. Manually turn ON your TV. 2. Press and "HOLD" CODE SEARCH 3. Press and release the TV button you want to set up 4. Release CODE SEARCH. 5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second). 6. Once the TV turns off, press and release ENTER. 7. With the TV on, press any other button. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-6.
If the remote is sending a signal and the unit isn't responding, the remote may need a reboot. If someone accidentally pressed multiple buttons at the same time, that can cause the remote to send multiple signals at the same time and that can cause the unit not to respond because it doesn't recognize the signal being sent.
The reboot is easy. All you do is remove the batteries and then press all of the buttons on the remote one at a time while they are out. After you've done that, you can put the batteries back in and usually that fixes the issue.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
