Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Lg dishwasher child lock
Door is locked how do I open it
5 Suggested Answers
Ian Greenland
  • 351 Answers
SOURCE: LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Posted on Mar 02, 2008
JEFF SIEGEL
  • 311 Answers
SOURCE: LG INTELLOWASHER DD 7KG DOOR LOCK STAYS ON WAY TO LONG
Never heard of that; I would try a new door latch as I have never had a bad control issue with the operation of the door latch. There is no real way to test it. I can getb you the latch if interested. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 29, 2008
Jeff Meyer
  • 423 Answers
SOURCE: door doesnot close
The LG LDS 5811 and all models that start with 'LDF" do not have a door latch. They do have a child lock _but_ that feature does not lock the door closed or open, it just locks the controls so the DW can not be turned on or settings changed.
So, please look at the right side edge of the opened door and post the model # back here.
Thanks!
Posted on Apr 10, 2009
Anonymous
SOURCE: lg washing machine wm-1460fhd door locked wont
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Posted on Jun 16, 2009
Anonymous
SOURCE: My LG flatron golden eye tv got Child Locked -
dear sir,
my tv had gone child lock problem & one chenal show the tv. please slove this problem. because remote has been not working.
Posted on Mar 09, 2010
How can I lock a renault megane 56 plate without the key card as it is not working
Locking/Unlocking the doors from the outside
This is done using the RENAULT Card; see the "RENAULT Card" information in Section 1.
In certain cases, the RENAULT card may not work:
- if the RENAULT card battery is weak, flat, etc.
- if equipment operating on the same frequency as the card (mobile phones, etc.) is used;
- vehicle located in a high electromagnetic radiation zone.
It is then possible:
- to use the key integrated into the card to unlock the front left-hand door;
- to lock each of the doors manually;
- to use the interior door locking/unlocking control (refer to the following pages).
Using the key integrated in the RENAULT card
Insert key 1 into the lock in the driver's door and lock or unlock. Locking the doors manually
Turn screw 2 with the door open (using the end of the key) and close the door.
This means that the doors are then locked from the outside.
The doors may then only be opened from the inside or by using the key in the front left-hand door. Interior locking/unlocking door control
Switch 3 controls the doors, boot and, depending on the vehicle, the fuel filler flap simultaneously.
If a door or the tailgate is open or not closed properly, the doors and tailgate lock/unlock quickly.
If you need to transport objects with the boot open, the other opening elements can still be locked: with the engine stopped, press switch 3 for more than five seconds to lock the other opening elements.
Locking the doors without the RENAULT card
For example, in the event of a discharged battery or the RENAULT card temporarily not working, etc.
With the engine switched off and an opening element (door or boot) open, press and hold switch 3 for more than five seconds.
When the door is closed, all the doors and the tailgate will be locked.
Unlocking the vehicle from the outside is only possible with the RENAULT card in the vehicle's access zone or using the key integrated in the RENAULT card.
Door and tailgate status indicator
With the ignition on, the warning light integrated in switch 3 informs you of the locking status of the opening elements:
- indicator light on, the doors and tailgate are locked,
- indicator light off, the doors and tailgate are unlocked.
When you lock the doors, the indicator light remains lit and then goes out.
Dec 12, 2015 | Renault Megane Cars & Trucks
How to open a deadlocked rear door.
Hi. remove the rear seat and door pad. You can access the lock through a small hole, break the top inner corner of the lock and it will release the dead lock and open the door.
Jan 29, 2014 | 2004 Volkswagen Golf
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
Right rear child lock is on the door but cant get the door open
Child Locks will stop anyone on the inside of the car from opening the door. If the child lock is on then the door can only be opened from the outside of the car. Of course the main door lock must be off just as any door must be unlocked to be opened from the outside.
Now if you do not want the child door lock to be on then you must first open the door from the outside with the main lock open or unlocked. Look at the space that is covered when the door is closed. There you will see the lever that turns the child lock on or off. Simply move it to the off position.
Good Luck.
Jun 22, 2011 | Toyota Highlander Cars & Trucks
Back door will not open at all 1994 infiniti j30 how can i get it open tried to take off panel not enough room any solutions need help
Did you check to see if the child safety lock may have been activated? If so the door will only open from the outside.Try removing the power door lock switch/arm rest assembly to see if the door lock switch can be jumped out in the event the door lock switch is burnt out.
Does the Infiniti have an exterior key lock cylinder on the rear door? If so try to get a key to open the lock, it may be very difficult to remove the door panel when the door is sealed closed, but if you can that may be your only salvation short of attemting anslim jim door opening tool down the side of the door glass in ho[pes to trip the door linkage lock thus opening the door.
Jun 05, 2010 | 1997 Infiniti.5 J30
Central locking
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
Apr 23, 2010 | 2003 Land Rover Freelander
Door Lock?
this is not a problem, it is a feature. its purpose is to try and make it harder to lock your keys in your car. try this: with the door open, pull the inner door handle like you are opening the door. with the handle pulled, lock the door. it will lock.
Nov 30, 2009 | Cars & Trucks
Back door wont open.
Are you moving the child safety lock or the door lock? Only the door lock itself should prevent the door from being opened from both inside or out. The child lock is typically a switch on the door near the door pin halfway down the door.
Sep 22, 2009 | 1995 Toyota Avalon
Door locks problem with one door drivers door
dont blame the idiot,we all make stupid mistakes without thinking and iam no exception,remove door trim and oil the solonoid with a oil can not a silly sunday mechanic spray and let it soak in as its working but i think its just a bit sticky with wear and dirt ingress hence it locks but doesnt unlock which might need a bit more power,oil the whole lot lock and all
Dec 05, 2008 | 2000 Renault 181
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
530 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
