Phone system was working fine on Friday morning. Then someone noticed their handset had the readout LKD-24D V0.6J SCOUT-DX V1.1 NO SYNC. All handsets on system are dead and have this readout. Tech has been on hold for over an hour waiting for support from Vertical in AZ. Meantime, we have no phones. Any ideas?
Greg is correct. Had one do this to me. Defaulting and reprogramming did the trick----after replacing the memory battery. The low battery is what caused the corruption in the first place.
If power cycling does not work, the next step would be to reinitlize the phone system. Caution, this will erase all programming and revert back to factory default. I have found over the years that the STSe Database can get corruppted and cause this display read out. If power cycling does not fix it this usu does. If it does not then there is a motherboard issue. Good Luck.
