Question about Dell Inspiron E1705, Intel Core 2 Duo T5300 , 17" WSXGA+ LCD, 1GB DDR2 SDRAM, 256MB ATI V... PC Notebook
Dell E1705...Same problem...lights on boot up
Stays lit thru Windows XP boot up screen and gets me to the logon where it then goes dark. In safe mode, it also goes dark in a few mins after boot up. I replaced the inverter board today since that should have fixed it but it didn't. Is it possible that the bulbs are bad? I don't think so because they work intially. It is possible that the inverter board replacement is bad but not likely. Please help...
  • Andy Dlinn
    Andy Dlinn Nov 20, 2012
    Thanks Hans...I actually just replaced the screen itself for $150! But that seemed to fix it. Thanks again for the input!
  • Dell Master
  • 3,606 Answers
Hello the homepage is here:
http://www.dell.com/support/drivers/us/en/ussoho1/Product/inspiron-e1705
Setup the power settings in the control panel so it not dim the screen after 5 min.set it for a longer period (This is a powersaving option)
Try also to install a updated screendriver.
The screen could also have a fault and must be changed.
Good luck
Posted on Nov 20, 2012
    Problem Solver:
  • 9 Answers
If the screen goes dark after BIOS, there is a software conflict - either a driver or screen resolution was set incorrectly. a couple of ideas to solve:
boot from disk, or another hard drive - if this works, it confirms the software conflict - which would mean having to re-install the OS.
Posted on Jun 28, 2009
6ya staff
SOURCE:
Dell Inspiron mini10
check if keyboard works during dell logo - try to press F2 or F12 - if no response need to replace keyboard
Feb 19, 2010 | Dell Inspiron Mini 10 Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
BOOTMGR is missing? dell inspiron e1705
maby you can use xp disk to startup computer and select the R from the menu thad displays than you are in the repair funktion
type help and you see a list .
type fixboot and enter
than type exit and now you are in the dos mode
restart and i hope xp wil also repair your bootmanager and computer starts normaly
download the windows relase version and burn it to disk .it are avalebel on microsoft webpage
good luck
Sep 01, 2009 | Dell Inspiron E1705 Notebook
Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Aug 28, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Dell 8400 Refurbished by with WinXP Pro preinstalled will not boot up. Gets past Dell XP Logo, then goes to blank screen with curser...however, keyboard locks up and can not get any further? What's th
windows is not loading properly.
if you're not worried about anything on the computer:
insert the recovery CD, boot the system to the CD, and reinsatll windows.
May 19, 2009 | Dell Dimension 8400 PC Desktop
Black screen after WinXP boot, same in Safe Mode
Pressing F8 during startup, just after the BIOS screen, will give you the
safe mode menu, including the option to create a '%windir%/ntbtlog.txt'
bootlog file
or you can try to restore xp:
Description of the Windows XP Recovery Console:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;314058
Mar 15, 2009 | Dell Inspiron™ 600M PC Notebook
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron E1705, Intel Core 2 Duo T5300 , 17" WSXGA+ LCD, 1GB DDR2 SDRAM, 256MB ATI V... PC Notebook Logo
266 people viewed this question
Ekse
Alun Cox
Thomas F. Schneider
