Rosetta Stone V3 Spanish (Latin America) Level 1 Personal Edition (Win/Mac) for PC, Mac (1580228542) Logo
A
Anonymous Posted on May 27, 2014
What format is dentimax backup file in? - Rosetta Stone V3 Spanish (Latin America) Level 1 Personal Edition (Win/Mac) for PC, Mac (1580228542)
Have connected a SimpleTech drive to MAC via USB and windows backup files are shown. I would like to recover Pic files out of the backup and place them on my MAC. Is there any easy way to do this?
You might have to restore the backup files from on your Windows machine, then drop/drag photos to a new folder. Windows and Mac's use different filing systems, so Mac's are unable to read the Windows backup file format.
tip
Backup iPhone SMS and contacts to computer
Easy way to backup iPhone SMS and contacts to computer
Want to save your iphone sms and contacts to computer for backup? To transfer your iphone sms and contacts information to computer, you need an iphone backup solution to help. This iPhone SMS Contact Transfer can transfer iPhone SMS and contacts to computer in clicks.
iPhone SMS Contact Transfer is a bundle of iPhone sms messages backup and ipone contacts backup. This bundle includes 2 software -- "iPhone Transfer SMS5" and "iPhone Transfer Contact". Now you can get this iPhone backup pack. Free download HERE
iPhone Transfer SMS can provide you:
- Backup SMS in iPhone to computer before iPhone reject receiving new SMS.
- View and Manage old iPhone SMS in your computer.
- View SMS in Text file format (.txt file), ANTS file format (.ants file), MHT file format (.mht file)on PC.
- Password protection support (ANTS file only).
- Edit SMS (ANTS file only).
- Print SMS (MHT file print by IE).
Free download it and try
All iPhone users can't backup the SMS to anywhere until the SMS box is full, then you have to delete all of them to prevent iPhone rejecting new SMS receiving. With iPhone Transfer SMS, you can transfer the iPhone SMS to computer as a txt file or a ANTS file before the event above happens. Before the transfer, you can choose to transfer from all contacts or a single contact, further more, you can choose transfer the SMS to a TXT file or a ANTS file. In ANTS file condition, you can protect the file with a password to keep your privacy. From now on ANTS file support edit feature just the same operation process as the SMS edit on iPhone. If you want print iPhone SMS, you can choose MHT file format, then open the file by Internet Explorer, print it just like shown on iPhone! No more words, please watch step by step guide: how to backup and transfer iPhone SMS to computer.
iPhone Transfer Contact can provide you:
- Backup contacts on iPhone memory to a file.
- Export two types of file format (Antc file, Text file).
- Backup iPhone Contact's Photos.
- Export full screen of iPhone contact's Photos.
- View Contacts in Text file format (.txt) or ANTC file format (.antc) on PC.
- Password protection support (ANTC file only).
Using iPhone Transfer Contact all iPhone user can backup the contact and contact's photo to computer. With Tansee iPhone Transfer Contact, you can transfer the iPhone contact to computer as a txt file or a ANTC file before the event above happens. Before the transfer, you can choose to transfer all contacts or a single contact, further more, you can choose transfer the contact to a TXT file or a ANTC file. In ANTC file condition, you can protect the file with a password to keep your privacy. No more words, please watch step by step guide: how to backup and transfer iPhone Contact to computer
Get more info about iPhone SMS Contacts Transfer
on Dec 10, 2010 • Cell Phones
Will i loose pictures & other files if i format my pc
Yes you will lose all files when you format.
If you want to save your files but cannot open Windows on your computer then remove the hard drive from your computer and connect this hard drive into an USB hard drive adapter. Plug this adapter and hard drive into the USB port of a working computer, this computer will see this as an external storage device, you can then open the folders on this drive and copy/backup the various folders and files.
After you have copied/backup your files, you can install the hard drive back into your computer to format and reinstall Windows.
2answers
I have tried to do a backup of my HP Probook 4520s for the first time using my new eGO !TB 3.0 Portable harddrive but about a quarter of the way through i get an I/O 0x8078002A error code on the device....
This error usually occurs because the portable drive was formatted using a newer Advanced Format with 4k sectors. The system backup tools in Windows 7 only support the older 512-byte sector format.
If your portable drive came with backup software, switching to that is usually the easiest solution. Other 3rd party backup software may also be compatible with your portable drive- I trust Acronis products, and they offer a free trial so you can see whether it will work for you.
Acronis True Image 2018 Overview
In some cases, it is possible to reformat the portable drive using an older, compatibility format. Note that you would lose any files currently stored on that drive.
More technical details about the newer formats-
Veritas: https://www.veritas.com/support/en_US/article.000020857
Microsoft: http://go.microsoft.com/fwlink/p/?linkid=325443
Won't back up files. Said 'The backup did not
reformat the removable storage device I assume its a thumb drive. go to my computer right click on drive g and select format on the menu, you have 2 choices to format in fat32 or ntfs of course the thumb drive should be formatted in fat32 so select fat or fat32 and do a quick format. that should fix your issue unless its a physical hardware problem with the drive. make sure you remove anything on your g drive that you can access and move to your computer because once its formatted everything will be deleted. after the format, start your backup again.
hope this helps and thanks for using fixa. please rate your experience and feel free to reply with any questions.
Running Windows 7 Home premium. External drive Verbatim USB 250 Silver is recognized, but, needs to be reformatted. I've tried to format (NTSF) using tool in Disk Management. Format runs forever and...
Hello and thank you for using Fixya's services.
This problem happens quite a bit with Windows Vista. It seems that Windows Vista puts a hidden file in the backup; which locks the device.
Open the external device (Windows 7 is fine). Click on "view hidden folders and files." Delete any hidden files you may have in the external.
Go back to "my computer" and right click on the external hard drive letter. Choose properties and security tab. Make your user-name as a main user (administrator) and disable the read only.
Reboot the computer and see if this works.
Please let me know if you have any questions.
1helpful
2answers
Hello, I have a new WD Elements 500mg
If you are using Windows Vista then format your external drive with exFAT (Extended File Allocation Table, aka FAT64), or NTFS. And if you are using Windows XP then only solution is to format drive with NTFS file system.
How to do that, just right click on HD from My Computer an click format.
3answers
I can send gmail through outlook exp. but can not receive gmail through outlook express
you need to go back and reinstall the program to your outlook mail then you gmail should work
7helpful
7answers
How on earth do i save my incoming text messages please?
Want to bckup your iphone sms and contacts to computer for backup? To transfer your iphone sms and contacts information to computer, you need an iphone backup solution to help. This iPhone SMS Contact Transfer can transfer iPhone SMS and contacts to computer in clicks.
Free download HERE
Top Rosetta Stone Computers & Internet Experts
vince
k24674
Vinho Xie
Vinho Xie
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
