Or you can buy a cheap 10 dollar ATA controller card to install.
But usely when the on-board controller starts to fail, other functions will also start to fail. If the ATA HDD can't be seen, a replacement board could help. If the drives are SATA, then get the raid drivers and install the drivers when windows asks if you have any software to install before windows continues - This would be for older main boards that didn't have SATA drivers installed in the BIOS.
Hope any of this helps - Have a great night.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
SOURCE: have emachines T5048.. boots up but shuts off
Sounds like you've tried everything but the motherboard, so I'd have to say that's where trouble is. You can find replacement motherboards online if you want to stay with the original board. If you do that, you won't have to reinstall Windows because the hardware will be the same, but it's a costly part.
You can buy any micro-ATX motherboard which takes the same processor and use that as a replacement. This gives you a wide choice of replacements at reasonable prices, but you'll almost certainly need to reinstall a fresh copy of WIndows and activate it since you won't be able to use the factory restore image. This isn't a bad thing, though, since you wind up with a system free of the stuff that typically comes preloaded, and is usually worthless.
