Dell Inspiron 1300 Notebook Logo
Posted on Jun 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Inspiron 1300 battery
I have problem with my inspiron 1300......i have a new battery ,but can not be charged.my laptop is working on ac adapter so i thing that the problem is not with ac adapter.pls help
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Jun 24, 2009
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1404347
Points
12062
If you have replaced the battery with a NEW one and it doesn't charge, then you either have an issue with the AC adapter (If the sensing pin is bent or broken in the barrel of the connector, the battery will not charge) or the charger curcuit of the motherboard. If the issue occurs on a different AC adapter, then FLash the BIOS to current version. If battery still doesn't charge, then replace the motherboard
Dell Inspiron 1300 Of front left four lights, the third is flashing red
I believe that is the battery light indicator saying that the battery is depleted. If you've attempted to recharge the laptop, I'd put my money on a bad AC Adapter. Try a different AC Adapter. Dell laptops are very picky, so I'd recommend acquiring a Dell-brand adapter to ensure it will charge your battery.
1helpful
Dell inspirion 1300 screen goes black
Turn OFF the laptop, unplug the ac adapter and remove the battery.
Without the battery and ac adapter, hold the power button for 10 secs.
Put the power sources back and turn ON.
1helpful
No power leds. My Ac adapter is new with the right voltage coming out. I have to keep on unplugging the power cord then the green light comes on my Dell Inspiron 1300
If the adapter is new or OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
3answers
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
2helpful
2answers
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Battery will not charge
Hi!
It's your ac adapter that is causing this issue. The ac adapter doesn't supply enough power or doesn't supply any power at all to the battery. Try to borrow another ac adapter from any inspiron system and if that works, then you need to replace the ac adapter, else, it's the motherboard.
Hope you find it helpful.
Thanks,
Karlox™ :)
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
