Where can i get a new switch/choke switch for this old motor. Have searched internet, but can't locate one. all wires one back old one has insulation cracked or gone. This maybe why engine will not turn over
Here's something to try. There are cans of plastic coat to dip stuff into to insulate them. Then you could also try to remove the terminals and use shrink tubes on the wires and then replace the terminals. If only for a short while you can see if that fixes the problem.
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
its on the ignition key ! as you turn it on to first position you then push the key in then as it starts let go and with the control lever on a slight high tickover you mite have to dab the choke a couple of times till it ticks over ! dont over choke or you will flood the plugs ! less is best and just let it warm up before setting off !
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) mercoutboard motors mercury outboard ... diagram of mariner outboard motors johnson outboardfuel problems ... johnson outboard motors ebay 1996115hp mariner outboard
There is a switch in the control box that locks out the start unless you are in neutral. Open the box and put in a new switch,this is a safty device to keep it from starting in forward and throwing you out of the boat. Jim OMC retired Mech
You may have enough room for a wrench. I have an old ignition set of small wrenches and those are slim. There is also a fitting called a crowsfoot which is thick like a wrench but short and fits on a rachet extension. The 1/4" drive set of sockets are usually shorter than 3/8th. If you have a camera, take pictures and go to Sears with it and buy something to work.
it may be your neutral safety switch. Try it again but this time turn the key with one hand and wiggle the throttle/shifter lever at the same time. My 25 johnson does this, but usually I can wiggle the shifter and she'll turn over. Hope this helps.
