Laptop, after being on for 3/4+ hours, makes very short buzzing/beeping noise. not caused by moving around. no reason for why it started happening. laptop about 3 years old, but very well maintained.
SOURCE: My laptop beeps everytime I try to turn it on and it makes a beeping noise.
Try removing the laptops battery for 1 minute & putting it back in. That should fix the issue.
SOURCE: 3 beeps at start
i had the same problem with the beeping, i changed the rams and now its working fine. works for me, good luck
SOURCE: DVD player on gateway laptop won't recognize dvds
ok you try with CD CLEANER DISC.if its canot help your DVD LOADER having defective please change it.
SOURCE: gateway laptop beeping
Check with the gateway beep code if you acknoledge the POST error beep you ear Or contact
SOURCE: I have a HP Pavilion dv6000 and the fan has started making noises
Its possible but it would require taking out all the screws from the bottom of the latop, taking out the keyboard and the screws from the top cover. Then disconnecting the ribbon for the mouse pad and any other plugs coming from the top cover. After you take off the top cover you'll expose where the fan is at and at that point you can clean it off. If it still makes weird sounds then the fan would need to be replaced.
