Kodak EASYSHARE M1063 Digital Camera Logo
A
Anonymous Posted on May 26, 2014
How do I fix my Kodak Easyshare M583? It froze while taking a picture.
1 Related Answer
Anonymous
  • 9 Answers
  • Posted on Oct 17, 2012
SOURCE: Where on the Easy Share Software can I direct my downloaded pictures from my M583 Kodak camera to my hard drive instead of Kodak Easyshare software?
use a card reader & put in the SD card,then copy from there in My Computer or if window pops up choose there.
1helpful
I LOST my software disc for m583 Kodak easy share. where can I get one - download one - for free? tks
You don't need one
You can download it for free on the Kodak website. Don't use other sites, because you can end up with lots of stuff on your computer and not be able to use it as you want. go here:
KODAK Support
There is a circle within the lens and when I take pictrues, there is a white shadow circle in the pictures. How do I prevent this from happening?
If the pictures taken are slightly misty, using a soft lens tissue (or spectacle cleaning cloth) wipe the lens delicately in one direction until the 'circle' has gone. Don't 'huff' on the lens as this will cause condensation INSIDE the lens.
If this fails to fix the problem, it may well be condensation build up inside the lens. If you have a sachet of silicone crystals (like the wee bags that come with a new pair of shoes), place the camera inside an airtight container with the sachet. Leave for minimum of 12hrs. This should absorbs any if not ALL of the condensation inside the camera.
Replacement lcd screen
The most difficult part will be to buy a new screen. I guess here are list of phone repair shops, that could do the job, but buying spare parts from Kodak is a challenge.
Pictures taken have horizontal lines on it
hello my camera is CANON CP1267 has a problem when turn it all right but the problem is when I want to take a picture appears error memory card that I can do tell me urgent thanks
Need software for easyshare M583 and kodak support says it no longer has it
You don't need any special software in order to use your camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
3helpful
My kodak m583 tells me there is lens obstructed,and wont turn on
This video illustrates troubleshooting steps for a lens obstructed error:
How to delete pictures
Hello, Push MENU button, scroll to set-up, scroll down to FORMAT
2helpful
Kodak m583 will not delete pictues when you use the trash can button
To the other so-called solutions: your "solutions" sucked.
Here's how to do it: Click the "settings" icon on the screen. You get there by clicking the sides of the silver square surrounding the "ok" button (if there are no icons on the screen then click the "disp" button). Then in settings arrow down to the option that says "safe mode" (near the bottom) and change it's value from "Yes" to "No". Then the "format" will become available (2nd option from the last). Format the internal memory. Tada! Clean slate.
Kodak easyshare m583
I have never seen a camera where the display actually contains the words 'blah blah blah' . Are you sure that you have read them correctly ?
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
