Philips Magnavox 9P6034C 60" Rear Projection Television Logo
A
Anonymous Posted on May 26, 2014
Why does my 2002 projecter tv have to much red in it
Toshiba 2002 projection tv 57h81 has red light no sound no picture
Projector TV's have a tube for each function e.g. Video 1, Video 2, TV. Does the TV just not work or the VCR<DVD<Game console modes not work as well? If one works and the others do not you should be able to replace that tube, module, piece.
I hope this helps.
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
I have a 2002 Philips 60 in. tv with the color
2) STK392-120 ICs and 4) 6.8 ohm 1 watt metal-oxide resistors.
My Projection TV immage looks out of phase with Red Horiz. Lines
The sony convergence repair kit Type 1 from www.tvrepairworld.com should repair that issue. The kit comes with the instructional CD on how to install the repair kit.
2002 akai 54in. rear projection tv wont turn on
Unplug,replug the tv back an hour later.The tv should reset itself.More problems repost,see if i can help u.
1helpful
Helpme
Replace Both of your convergence ICs they are big black ics STK392-110? use 180s .
1helpful
2answers
Red ghosting on rear projection sony tv year 2002 how to fix
The model number is KP-53HS30, the screen is blurry displayin colors of red green pink
3helpful
Sony 57 in Rear Projection TV
If the picture is playing fine and you notice that the background is getting more and more red, until it is too red and the set shuts down, it could be that the red screen control is set just a bit too high. If this is the case, you can probably correct this yourself. If you are watching a perfect picture and then it suddenly flashes a very bright red, with thin red lines in the pictureand then shuts down, it usually means that the red picture tube has developed a short in it, between the cathode and heater. A good tech might be able to remove the short by arcing, but if the short persists then the red tube will have to be replaced. Either way, this is something that should only be done by a qualified tech.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
