KENMORE WASHER MODEL 970-C47092-10
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
SOURCE: Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
SOURCE: Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
