SOURCE: How do I clean or replace the drum on a Ricoh
The drum unit on these models is a complete replacement unit. the drum can only be cleaned by removing the unit and then there are some screws to be taken out. two on the back plat and two on the front. if you take these cover plates of the unit will split and you can remove the drum(Blue roller) and under neath there is a charge roller as well that can be cleaned.. only use water on the black cahrge roller and gently rub with a cloth till clean. The drum with a very soft cloth and some liquid brasso may clean it up or get rid of the scratch lines but if they are too worn the drum needs replacing. you can clean the scanner glass and the mirrors underneath here as well.B0392201 is the part number for the Drum unit which comes as a complete unit. you may need to purchase the developer for the drum init as well B0399640 is the part number for this. hope this helps >>>A
Testimonial: "Thank you this is helpful"
