Dometic 3106995.032 Analog Thermostat Heat Cool 3107612.008 Logo
A
Anonymous Posted on May 26, 2014
Wiring diagram for duo therm thermostat # 3106995.032
william simpson
Level 3:
Genius:
  • Dometic Master 1,363 Answers
  • Posted on Aug 16, 2015
william simpson
Dometic Master
Level 3:
Genius:
Answers
1363
Questions
14
Helped
317748
Points
1636
Download it from dometic corp.
5 Related Answers
Anonymous
  • 357 Answers
  • Posted on Jun 27, 2008
SOURCE: Duo Therm Thermostat
Hi there
I think this is a setting on your air conditioner, the air conditioner will turn off when the room is at the correct temperature and when the room starts to warm up, the air conditioner will turn back on. (You need to find the settings and change them from auto-adjust to manual-adjust)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Anonymous
  • Posted on Jul 19, 2008
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Aug 14, 2008
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Anonymous
  • 127 Answers
  • Posted on Jun 29, 2009
SOURCE: a duo therm thermostat (p/n 3105058) was removed
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Anonymous
  • 534 Answers
  • Posted on Oct 30, 2009
SOURCE: We have a duo therm rv analog thermostat. When we
red wire to the r section of the thermostat white (heat) to the w marked on thermostat Green (fan) to the g marked on thermostat yellow (a/c compressor) to the y marked on thermostat. Blue to the c marked on thermostat. Orange to the orange marked on thermostat.
Need a wiring diagram for duo therm thermostat in a 1994 Kountry Star motorhome
didnt specify model number of stat --can notify domestic they make the duo therm products
dometic com
What replace Duo Therm Thermostat 3105356.001
Can you attach a picture? Does it look like this one?
New digital therm. air works but no furnace can be found on therm.
What make and model of AC, as well as Make, model of thermostat ? Need that info for proper diagram.
How do i wire analog thermostat to digital
You need to get a different thermostat.you can change an analog thermostat to digital, but you have to replace the motherboard with a digital compliant one. You can't just change the thermostat. Your best bet is to put back the old thermostat or upgrade to a different compatable thermostat
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
1helpful
I have an old mobile home that has and old duo therm thermostat that is acting up. keeps cycling off for quite awhile and on for not so long. I purchased a honeywell ct-31-a. It only has places for 4...
If you want just heat, connect the red wire to the R terminal, the White wire to the W terminal and the green wire to the G terminal. Confirm that these same wires go to the same terminals on the control in your furnace. If you want both heat and air conditioning, connect a jumper from R to R2. Keep the wires the same as I described and put the yellow wire on the Y terminal.
3helpful
3answers
A duo therm thermostat (p/n 3105058) was removed because it would not operate the air conditioner/heater in a firan fireside camper. it was knocked loose from the wall damaging it.the thermostat is for use...
provided.
3helpful
5answers
Duo-Therm by Dometic Thermostat
red and white are positive and neg 12v
green is low fan
grey is high fan
yellow is cooling
blue is neg 12v(marked B-)
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
