Washing Machines Logo
A
Anonymous Posted on May 26, 2014
What are the electrical specifications for a Kenmore Elite 20972 washing machine?
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 10, 2008
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Anonymous
  • 5911 Answers
  • Posted on May 15, 2009
SOURCE: water leak, back of washing machine during rinse or drain cycle.
The back panel does not come off. You need to remove the outer casing in order to access the internal components. The following steps explain how:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
With the case removed, you should now have full access to all the internal components and be able to complete a thorough inspection. If the leak is coming from the rear of the washer, check your water inlet valve and associated hoses. Inspect the tub ring where the water dispenses into the wash basket and make sure it is not cracked, or has any loose hoses. If you need assistance in determining where the leak may be coming from, please let me know.
To reassemble the washer, perform the following steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have any questions along the way, please let me know. I hope you find this information helpful.
Anonymous
  • 42 Answers
  • Posted on Aug 01, 2009
SOURCE: Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Anonymous
  • 6 Answers
  • Posted on Jan 19, 2010
SOURCE: F32 - Kenmore Elite Front Loader Washing Machine
These codes means that the CCU and the CMU are not talking to each other. have you moved lately or some how disrupted the connections from these modules? I don't believe your modules are bad but you'll need to have a technician check and re-secure the connections to your modules and this should solve your problem.
Anonymous
  • 15935 Answers
  • Posted on Sep 18, 2010
SOURCE: I have Kenmore Elite Catalyst Washing Machine.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sour smell in kenmore elite top loader
Try putting a cup of amonia in with your detergent,when you wash.
My dryer is barely getting warm so it doesnt dry very well.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Not drying through single cycle
heatman101
The spin cycle will not work. Any suggestions?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
WILL NOT DRAIN WATER WHEN SPINING
check the drain hoses from the wash tub all the way to the drain for kinks or obstructions,then check the pump body for damaged impellers or debris inside such as coins, etc
Washing machine doesn't spin..clothes are soaking wet @ end of cycle
this could be due to blockage @pump or the motor wont spin if water not pumped out ..Check filter/clear pump.please leave me me feedback.
1helpful
My top loading kenmore elite washer model #20972
No, this is probably a direct drive that has a faulty plastic coupling from motor to transmission. Go to:
http://www.fixya.com/support/r385252-replacing_motor_coupling_W... by jsrock516
Please give him a pat on the back for the help.
Motor not working
Your motor is attached to the pump,your pump seal is locked up needs replacing or purchase a new pump.Because it is a job replacing seal,if your a first timer.
1helpful
Kenmore elite dryer model #110.63952102 start button wont stay on everything else works
I have the same problem with my Kenmore Elite dryer (model#110.74992300), and I replaced both the motor and heater relay and the problem solved. You can get the relay from www.mouser.com for $3 each. The model for the relay is T9AP1D52-48. You may want to open up the dryer to verify the relay model, it is printed on the relay.
Alexander
vince
