Question about Yamaha 2009 WaveRunner FX Cruiser SHO
Jet si cavitates after running awhile - Yamaha 2009 WaveRunner FX Cruiser SHO
Pump runs normally with no water but surges when filled with water
When there is a load on the motor and it is surging this is an indication of not enough water getting to the front of the pump.
Check the water flowing inside the tub going from the jet opposite the suction cover.
Sounds to me like you may be getting cavitation because the pump is pulling in too many air bubbles from the jet.
Close the air control and/or move the direction of the eyeball from pointing at the suction cover and see if that helps.
Rod
US Parts Center
Apr 09, 2014 | American Standard Home
When pump runs it is very loud
depending on the noise, it could be cavitating, due to air leaking into the inlet side, or it could have faulty bearings. If its a screechy noise, then probably bearings.
Dec 10, 2013 | Goulds Pumps 1HP J10 Deep Well Cast-Iron...
Utilitech jet pumps
This sound could be many things. It could be cavitation from a suction obstruction. IT could be a bearing or a bushing. IT could be something lodged in the impellors. YOu will have to take it out and disassemble it to see.
Dec 09, 2013 | Plumbing
Mower ran out of gas now it wont start
Hi and welcome to FixYa, I am Kelly.
Carbs all have some minimal derbis in the float bowl. When an engine runs out of gas the float bowl cavitates and the debris that was just fine in the bottom of the float bowl is drawn into the main fuel jet located in the threaded area of the bowl nut. Remove the float bowl nut and bowl. Use carb cleaner to remove the debris from the main fuel jet orifice in the threaded area of the carb body.
(If the carb cleaner does not free the debris from the main fuel jet is can be unscrewed and removed for cleaning. Just make sure the screwdriver is a good fit to the brass slots of the orifice or you will never get it out.)
Make sure to clean out the float bowl and nut before re-assembly. This should get you going pretty quickly.
Thanks for choosing FixYa,
Kelly
Jul 10, 2011 | Husqvarna 675 hp 21" Honda Rear Bag Push...
What is the zip code of cavite
Cavite City - 4100
Cavite Naval Base - 4101
May 15, 2011 | Computers & Internet
The pump surges where's the impeller
if your pump is surging then you do not have enough water in the bathtub or you have a jet that is blowing air into the suction fitting. this happens a lot when a jet faces the suction and the air control is wide open. the suction pulls in too much air and causes the pump cavitation (surging). Try pointing the jet opposite the suction cover upwards and see if that doesn't solve the problem.
Feb 16, 2011 | Maax Pearl By CS60wh Pearl CS60 in White
Can i get another voters id in comelec because i lost it...asap
hi ako pala si benjie taga cavite city po ako matagal na po kasi hindi ko pa na kukuha ang bago kong id voters na wala po kasi youn
Jan 22, 2011 | Car Audio & Video
Continual gurgling sound coming from the well
the pump may be cavitating. caviation often sounds something like rocks going through a pump. this can be caused by the suction line or strainer of the pump is plugged. if continues to run the pump will have unrepairable damage to the casing and will the to be replaced.
Apr 03, 2010 | Jet Plumbing
Rooster tail is not shooting high
If the waverunner is performing normally as far as throttle response and top speed, then the rooster tail not shooting as high as it used to indicates there is a restriction in the nozzle for the rooster tail, not a problem with the ski. Unbolt the rooster tail nozzle from the steering nozzle and inspect it for debris.
Jul 13, 2009 | Yamaha 12V Air Pump
Yamaha 2009 WaveRunner FX Cruiser SHO Logo
74 people viewed this question
Top Yamaha Boating Experts
Colin Stickland
Colin Stickland
Mike
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
