SOURCE: rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
SOURCE: a bulb blew in my tecnik cooker hood and neither
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into
the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
