SOURCE: Drivers for Toshiba Satellite A135-S4527
type this in your search engine ....
toshiba support-content list
some tittles of exactly what you typed in will display...
click on one and youll be at the download page...
just been there.I'd type the page in for u but its very long as youll see when u get there.
SOURCE: All for Toshiba Satellite P205-S6287 notebook
I am thinking that he just provided a set of drivers for this Laptop...
He simply put it there and said nothing...
Let's try it. http://rapidshare.com/files/57546874/XP_Drivers_laptop_Toshiba_A135-S4527.rar
SOURCE: Windows xp Driver for satellite A135-S2246
i have the same issue before. i have all the drivers that will work for windows xp. hit me back if youre problem is still not fixed.
SOURCE: My brand new Toshiba SAtellite C850 F31Q screen stays black on startup. What can I do?
Got this from another site, since I had the same problem:
The problem is with the power settings, not the OS or anything else
Here are the fix steps:
1. Turn off your computer
2. Disconnect every wire from it (including power)
3. Disconnect the battery from the bottom of the computer. There will be two tabs labeled 1 and 2.
4. Re-plug in the power wire. (the battery should not be in the computer)
5. Turn on the power. The screen will work. Choose start windows normally. (if you get that screen)
6. Go to Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings
7. Choose Change advanced power settings
8. Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in.
9. Click Apply then OK
10. Shut down you computer.
11. Disconnect the power cord.
12. Re-install the battery on the bottom of the laptop, plug in the power cord, and restart the computer. "
