Zanussi ZDF490 Electric Double Oven Logo
A
Anonymous Posted on May 25, 2014
Zanussi zdf490x element - Zanussi ZDF490 Electric Double Oven
1helpful
Our ancient Zanussi ZSA15 oven isn't working. Everything else is - lights grill etc. Guess it sounds like the element around the fan. Can I fix this (unlikely), is it worth replacing?
ONCE AGAIN, A SIMPLE GOOGLE SEARCH!
I WISH PEOPLE WOULD LEARN TO USE IT INSTEAD OF BOTHERING US!!!
Zanussi ZSA15 oven parts
Google
This is the official Zanussi parts website.
Click on Cooking then select heating elements.
Official Zanussi Site Parts Accessories for Appliances
You'll need to find your Appliance Product Number, the page tells you what to look for.
On this website, your ZSA15B or ZSA15W (probably stands for black or white) Is listed. It lists 3 different replacement elements.
Zanussi ZSA15W Elements
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
2answers
Fan oven not heating up
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
The element has blown on my Zanussi ZBF860 oven. I
You should be able to remove the element without removing the oven. Open the door and remove the back panel, normally 4 screws. This will expose the element. Then it should be 3 or so screws holding the element to the frame, remove these and slowly pull the element towards you carefully, then remove the 2 wires from behind and make sure they don't fall back into the oven as you will need to remove the back panel to get them. Then reverse process to install new element. Hope this helps.
2answers
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
1helpful
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
1helpful
2answers
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
15helpful
2answers
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
2answers
Oven not working
Top Zanussi Ovens Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
