Good Morning Friend,
I understand that you are receiving a CO code on your Frigidaire Professional Series dishwasher, model# PLD3465REC. C0 means that there is some type of communication error. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: frigidaire professional series dishwasher, PLD2560LCC1
It is a bad control board. Mine just had the exact same problem and I replaced the board. It is available from the Sears online part store for $112.00. It is not hard to replace if you are somewhat handy.
SOURCE: Frigidaire Dishwasher Professional Series runs
There's probably some garbage clogging the pump.
Take the lower basket out of the dishwasher. Remove the lower spray arm. Remove the screws holding the upper pump housing and if necessary any hardware located right under the spray arm. Inspect and clean as needed. Also check the spray arms to see if there is any debris inside. I've found bleached and hardened beans, paper wads and soap/lime concretions in spray arms. I've even found a plastic pull strip from a frozen juice can in the pump (that was LOUD!).
SOURCE: My Frigidaire Professional series dishwasher will
Here is a tips that I wrote
that will help to explain why you get the PF Error Code
PF
Error Code for Appliances
heatman101
SOURCE: My frigidaire dishwasher is blinking lights and a
PF
heatman101
Good Afternoon Jodi, thank you for your post!
Based off what you have described your Frigidaire dishwasher is displaying an error code "CO" and will not run. An error code of "CO" may be a miscommunication within the control panel and you can clear that error code by disconnecting power from it for roughly ten minutes. If you continue to experience an issue with your dishwasher I would suggest contacting a professional technician for a diagnosis to be completed. I hope this information is helpful. -Matt
Hello Teresa Ann - Typically error code UO indicates that while the dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly and that the vent plunger is in a closed position. A professional will need to check the wiring between both parts and depending from the results either part may need replacing.
PF
heatman101
