When i turn on my motherboard, all of fan n LED indicator is work, but there is no respon to the screen and no beep sound as ever before show bios screen. any one solution? Thank you for any advice
Remove 1st the video card. reboot and wait for the beep, if none remove the ram and reboot again, when there is beep, maybe the ram was defective. replace ram then put the video card back. reboot. if still not working. remove again the video card and plug the monitor to the on board video. reboot, then wait...'til post. if this doesn't solve your problem then you need to buy new motherboard. if it work replace the video card with working or buy new.
SOURCE: Starting PC: No Beep, No LED on motherboard, all
This MAY be the power supply. Fans often run from different voltage than most of the processor.
The power on reset may not be releasing as one of MANY possible problems. Power supplies are less expensive to try tahn motherboards.
SOURCE: i think i have a dead motherboard
It may b ur RAM is Corrupt Plz Replace ur RAM if Problem is persist its mean fault in Ur Motherboard.
SOURCE: my motherboard msi g41m4-f...... no
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
SOURCE: 880GM-E43. Worked without a problem for
I'd have to agree; bad power regulator on the motherboard.
The board is getting some power (3-5v) since the CPU fans move, but it's not getting the 12v it needs to power the processor, RAM, etc. (No onboard power LED). Sorry for the bad news!
