Be carefull, never use force. Check if you don't try to put in the card the wrong way around. Then check if nothing is damaged inside the memory slot. You need a bright light and perhaps a magnifying glass, because everything is very small. Compare the memory slot with a memory slot from another camera. Watch how the little knobs on the side look. I don't mean the contacts. When the contacts are bent, there is a possibility someone once pressed a memory card in the wrong way around and damaged the contacts and knob to secure the card.
SOURCE: memory card loeck
Have you tired to unlock memory card unlock button ? SD cards do have write protection physical lock. take a look at this pic and unlock it, good luck!
SOURCE: memory card lock
So you're having problem in your memory card?
Try this:
1. Take out your memory card from the camera.
2. There's switch to lock and unlock on the memory card.
3. Just unlock it, and put back your memory card.
Hope this help! PM me if you have another questions.
SOURCE: Card locked problem
If you've already tried the slide switch, see this link for additional things that you can try.
SOURCE: When i insert my memory card it says
Is it a new 4GB memory card? If so that might be your problem. The card would likely be an SDHC card, and your camera was designed well before the SDHC format came out. Your camera can only use standard SD cards (2GB or less).
But if the card is less than 2GB, it could have become corrupted. In this case you could try formatting the card in the camera to see if this would rejuvenate it. This will also erase the card. See this post if you wish to first recover those pictures.
Finally, if this is occurring with multiple cards, and is also saying "card locked" even though the tiny slide switch is in the unlocked position, then see this post for a possible remedy.
SOURCE: 'memory card error - card locked!'
pull the card out
find the slide button on the side and slide it to the "unlock" position
put card back in
enjoi
