Canon PowerShot SX10 IS Digital Camera Logo
A
Anonymous Posted on May 25, 2014
My memory card won't lock in place therefore I get a "no memory" card message.
Vick
Level 2:
Scholar:
New Friend:
  • Expert 92 Answers
  • Posted on Feb 12, 2015
Vick
Expert
Level 2:
Scholar:
New Friend:
Answers
92
Questions
0
Helped
16381
Points
259
Unfortunately it sounds like the locking clip inside the SD card slot is broken or some how stuck? If you can try to look inside the SD card slot in the camera with a flash light, there should be a small clip like plastic to the left sticking out. That is what locks the SD card in place. See if anything is stuck in between like debris, you might gently poke that clip and see if it is stuck? That is what locks the SD card in place, if it is broken or missing, that will require some work to replace the plastic lock.
3 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Sep 17, 2007
SOURCE: Memory card will not lock in place...
what type of card?
Anonymous
  • 11967 Answers
  • Posted on Dec 11, 2009
SOURCE: i keep getting a message memory card locked on my. It says memory
Move the slide switch on the side of the card.
Anonymous
  • 1894 Answers
  • Posted on Jan 17, 2011
SOURCE: Everytime we start our cannon
i think you have a faulty card. get a cotton swab and clean the golden contacts over the memory card. If problem pertains then get a new memory card.
I. have canonelph 300 hs and i. can not reset all when i. try to do that i.get busy message
I must have posted a clarification instead of a solution therefore:
Check the memory card for a "Lock" switch. It may be locked.If you are viewing the memory card via the cable via computer, this can happen in thumbnail mode of the computer if you are not using the camera bundled software and you have many images on the card. Also make sure to set in your computer's folder settings "Do Not Cache Thumbnails" is enabled otherwise your computer will try to be saving a thumbnail database file on the memory card.If you have a card reader available to use, you can use that as a quick way to delete images from the memory card after transferring them.
1helpful
Memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
"Card Locked" message comes up periodically and
Switch of the camera and eject the memory card. carefully take a look @ d side of the memory, u'll find a botton with an indication of Lock and Unlock. Move the botton to the Unlock indication.return the memory card back into the camera carefully and dats all.
2answers
My camera says protected card. What does that mean, it won't let me snap a shot or nothing
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
On my Lumix DMC-TZ3 Panasonic Camera- the memory card won't pop out as it aleays has-tried pulling it and it won't come out-don't want to damage the camera-any suggestions?
Hi, fitzarc , and welcome to FixYa,
Everyone should be telling you that this is a problem best solved by the manufacturer or a trained service technician, and they are correct, but if you are determined to do this yourself, you might try the following:
Some camera digital memory cards have a "lock" tab of the side of the card and this is used when you do not want the contents of said card to be overwritten.
Often times, that tab will protrude just a wee bit, enough to lodge itself in its track and therefore appear to be stuck.
I have solved this problem on my own camera by taking a small pair of needle-nosed pliers , grabbing the card and GENTLY moving it back and forth while GENTLY pulling it out.
It's worth mentioning here that buying a good memory card that is sturdy, reliable and a known brand name. Some camera manufacturers provide a lower end memory card and these typically have problem like you're experiencing as well as having trouble retaing data- in this case, your photos.
Good luck and let us know how you go!
Aug 10, 2011 • Cameras
My memory card in my canon camera suddenly won't let me take or delete pictures because it says card locked. - have been using it without a problem but then today it suddenly said "card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Aug 04, 2011 • Cameras
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 • Cameras
I have a stylus 600 model, if i place the memory card in the cam a message will display in the screen..."write something"....what does it mean?
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
The message said "card locked" so I bought a new memory card after several attempts to fix it. With the new card in, the message now reads, "card unreadable"
Make sure you're using an SD card, 2GB and smaller. The M537 won't work with higher-capacity SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
4helpful
Card Locked Samsung SL 102 Camera
there is a lock button on the memory card check it if it is SD card or camera might not support the card try 1gb card
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
