Bios software is not present gigabyte GA-6vxe7+
Go to this site and download the Bios and burn to a CD in order to install the bios on the motherboard. http://www.gigabyte.com/products/product-page.aspx?pid=2410#bios
SOURCE: Gigabyte GA-8VM800M 478 - On-board VGA as well as ASUS N6200 vid card
this can support two monitors. but it means one through the dvi output and one through the analog and have the desktop spread over two screens..If you need help locating these ports then ask me..
SOURCE: Compatable gigabyte ga 81915pm motherboard
you may not have to format
you should be okay
are you sure power supply is not going
remove cd drive and boot see if you can get to safemode
Are you sure you have'nt had pc opened and maybe loosened a memory
I still don't think it's the motherboard.I would go more for a memory or power supply problem
let me know
SOURCE: Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
http://america.giga-byte.com/FileList/Manual/motherboard_manual_ga-8vm800pmd-775_e.pdf
Before installing the memory modules, please comply with the following conditions:
1. Please make sure that the memory used is supported by the motherboard. It is
recommended that memory of similar capacity, specifications and brand be used.
2. Before installing or removing memory modules, please make sure that the computer
power is switched off to prevent hardware damage.
3. Memory modules have a foolproof insertion design. A memory module can be installed
in only one direction. If you are unable to insert the module, please switch the direction.
1-4 Installation of Memory
The motherboard supports DDR II memory modules, whereby BIOS will automatically detect memory
capacity and specifications. Memory modules are designed so that they can be inserted only in one
direction. The memory capacity used can differ with each slot.
SOURCE: Gigabyte GA-945P-S3
1. 4 DDR II DIMM memory slots (supports up to 4GB memory)
2. Supports 1.8V DDR II DIMM
2. Supports dual channel DDR II 667/533/400 DIMM
SOURCE: My Gigabyte GA-G31M-ES2L Motherboard BIOS is
Try this link:
http://bios-repair.co.uk/bios/bsrecover.htm
