SOURCE: A-1 code on Hotpoint FDF 780P - can I fix this?
A01 is an overflow or water in the base.
What you need
to do for this is pull the machine out and tip 45 degs backwards this
will allow the water to drain out from the base. Once the water is out
this will reset the antiflood device.
Then reset the program and restart a new cycle and see how it goes from there.
If
it does it again then there's a leak in there in which case you need to
pull the machine out and take off the top and the right hand side panel
and try and locate the leak.
