SOURCE: i inserted my Apcer USB 1gb flash drive, it was
Is there anything on the disk it self? If there is/was a virus on the disk, it could have left a 'autorun.inf' file on it ... So try Right-click and select explore. Or try to access it via the Total Commander
If that doesn't work, try formatting the disk.
This is an often problem with most low-end flash disks.
Did you receive some software with that disk?
SOURCE: my pendrive can detect but it appear please insert
it means that it is containing some viruses...try to format it...its a very frequent problem that is occuring now a days in memory cards...may be its having the problem in its circuit...do those steps or otherwise claim it for warranty if it has.....
is this cleared your problem?
SOURCE: I have an 8gb flash drive, it just so happen that
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
SOURCE: Insert the disk drive in H:
Friend your flash drive is defective or either its connector. Got to an authorised repair shop and check it out.
Testimonial: "Thanx..."
