Craftsman 29cc 4Cycle Straight Shaft Weedwacker Gas Trimmer () Logo
A
Anonymous Posted on May 24, 2014
316.731701 doesn't engage
Jerry Ross
Level 3:
  • Master 1,121 Answers
  • Posted on Nov 22, 2016
Jerry Ross
Master
Level 3:
Answers
1121
Questions
7
Helped
355045
Points
2563
Not sure what you mean but if you are saying the weedwacker head is not engaging it may be the cable that goes from the motor to the weedwacker head and runs down the inside of the shaft.
2004 Ford Taurus won't start?
get your battery checked
Air Conditioner Compressor Clutch Problem
If you did not use a vacuum pump from a dry system them the system will not work.
1helpful
Sprocket doesn't engage anymore. You can hear it turn on but doesn't move . I was told torque can be adjusted .....how?
on the operator there is either a sensitivity setting for up or down,most likely if you take the cover off of unit you will see a round nylon gear about 4",my guess is,its stripped
Starter won't engage on 17.5 koehler command
Try replacing the solenoid. If that doesn't do it, replace the starter.
The free wheel engages when we are going after five minutes ish
I HAVE KINDA SAME PROBLEM. When I to use it doesn't engaged. I have rock it back and forth to make work. Took repair 2 times, they blow the clutchs out air. Dust in the clutchs. It doesn't work for me. They can't get it not to work.
Mar 20, 2012 • Garden
My 4wd doesn't engage at the front axle
on my 2001 jimmy i had the same problem i fixed by changing the actuator on the front diff very simple and inexpensive
Car died and wont restart
If the starter turns but doesn't engage then the starter relay is defective. Have it replaced.
When engaging the moer it doesnt want to start
The tractor has a safety feature that doesn't allow you to start the engine with the mower engaged. Just disengage the mower, then start the engine. Once you have it running, then engage the mower.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
