SOURCE: my garmin nuvii 200 is stuck on a foreign language
Ah ha, someone decided to play a little joke with your Garmin. (I've done the same with someone else's cell phone; set it to Portugese and they'll search for days to correct it!) Fortunately, all of the Garmins I've played with are typically icon driven menus. I'll assume you touched the wrench icon in the lower right corner to get into the setup display. From there, you should see icons for 'Map', 'System', 'Time', etc. If you don't see the 'Language' icon, use the down arrow to go to the next screen. If that doesn't help, I would do a factory reset and that should take you back to the factory settings.
SOURCE: How do you change the language from German to English
http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf
Page 46, follow the icon prompts to change to English. If this solves your problem, please come back and rate our solution. Thank you.
SOURCE: Foreign language text on GPS device
Click on the wrench tool button, then the picture of the sprockets which is system, then click the lips/mouth. Once there, you should be able to change the voice and text to English. Just click on one of the boxes to change it to your chosen language.
SOURCE: I want to change language from spanish to english on garmin 265
use settings language and scroll left or riht until ENGLISH appears in the box
izquierda is left right dirreccio
acceptar is the one to accept
SOURCE: how to change language on a 255?
On the very first screen after the GPS boots there will be an icon of a
wrench at the bottom right of the screen. Press that Icon and scroll
through the menu and you will find a language setting.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Testimonial: "Thank you! Merry Christmas!"
