Just opening pool up for 2 nd yr and turned on pump and making really loud constant noise ?????
SOURCE: noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
SOURCE: pool pump is very loud
loud pumps are most times caused by bad bearings and need to be replaced or better yet replace the whole pump new bearing cost about $100 to replace but not always easy to find someone to do hope this helps
SOURCE: I have an A.O.Smith Century Pool & Spa motor
THIS IS LIKELY CAUSED BY SOMETHING IN IMPELLER TURN OFF POWER SEE IF YOU CAN SEE ANTHING IN IT YOU HAVE TO TURN HANDEL VALVES OFF PUSH DOWN IF YOU HAVE TO OPEN PIPE IN FRONT OF PUMP I
SOURCE: 2 yr old inground pool Hayward pump louder than
If there is air in the pump it cavitates and can make it run louder, otherwise it is the bearings in the motor.
SOURCE: I have Hayward Centurian SE 2 hp pool motor
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
