Roper RT21AKXKQ Top Freezer Refrigerator Logo
A
Anonymous Posted on May 24, 2014
What is the cubic feet of the Roper RT18DKXJW01 by Whirlpool
How many cubic feet is this ROPER REFRIGERATOR ?????
25 cubic feet. It is the RS25 in the model number.
Described here as well
https://www.shopyourway.com/questions/1118241
Whirlpool dryer model #LG7681XSW2 what is the cubic ft of this dryer? 22000 BTU...serial # MAO143334
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
What is the cubic feet capacity of this dryer?
what is the dryer, roper,whirlpool,kenmore,etc... what is the model
Apr 17, 2011 • Dryers
8helpful
2answers
How big inside (cubic ft.) is the Roper refridgerator
20.9 cubic feet for model # RT21AKXKQ
14 cubic feet for model number RT14BKXKQ05
1helpful
Hello, RE a 1980 Kenmore 20821 Large capacity washer 1) the machine does not extract fully. I have tightened the belt which was loose but that has not corrected the problems. Also, I would like to know...
I would you recommend you make a burial date for that machine. The best ones out right now are whirlpool, or one of their models like roper etc... just get the standard models. I do not recommend front load models. This goes the same for the Fridge. The better one out is whirlpool, maytag and the other models are having a bad compressor issues... let me know if i can be more assist to you.
1helpful
I have a Roper refidgerator; can't find the serial or model number or name. Where is it?Can't find the fan that suposed to be located by the compressor, under the fridge, where is it? Works fine but has...
The model and serial number are usually located on one of the inside walls of your box. The condenser fan you are looking for is underneath the box. You might have to take some screws out from the back side of your fridge to access the fan, and coil. The coil must be clean for proper heat rejection. If you want to calculate the cubic feet multiply the hieght, width, and depth together. For instance a fridge that is 7ft tall x 3ft wide x 3 ft deep would be 63 cubic feet.
Top Roper Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
