I have changed the water inlet value and checked everything for blockages, but it still won't wash with any force. Water comes out of the lower washer, but only a few inch spray. Nothing comes out of the top washer. It seems to be cycling fine - fills, washes, drains, heats, but just not enough pressure to do the job.
With your dishwasher empty, roll out the bottom rack. The feed line for the upper spray arm runs from a pump outlet directly behind the lower spray arm spindle. This tube runs up the back wall of the dishwasher and mates with the upper rack when it is pushed in.
This feed tube simply snaps into place in the bottom of the machine. It is a high pressure line that makes an immediade 90-degree bend towards the rear of the unit. They have a tendency to pop out. When and if it does pop out you get almost no water coming out of the upper arm and you lose effective pressure in the lower arm, too. The cure is to push that feed tube back down firmly into the port until you hear it snap into place. While you have the lowere rack out it is a good idea to clean the intake screen out and check for any debris in the intake well.
Hi
When the Dishwasher won't fill you'll need to
check for the water inlet hose, the water inlet valve and the float switch
assembly. When the water fills your dishwasher, a float rises along with it. As
the float reaches a certain threshold level, it shuts off the flow of water,
thereby preventing a leak. Sometimes the float can get stuck in the wrong
position in your dishwasher, and it can prevent your dishwasher from filling.
Sometimes it can happen due to float valve and on other occasions due to float
switch. Inspect the water hose coming to the dishwasher for any blockages. If the
hose is not clogged then check the water inlet valve for any clogs, if the
water will not even fill for few seconds then certainly the water inlet valve
is bad and should be replaced. You can also use a multimeter to check
continuity on inlet valve. If you don't get any value on the multimeter then
you'll need to replace the water inlet valve assembly. However, if the valve is
fine then the float switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
Hi
Daniel
