Possible that you gat a slow shutter speed. Or your camera might be getting faulty. When the shutter gets damaged then the blurry focus wont change unless its fixed. The four main causes of blurry photos are:
Out Of Focus
The subject moves while the shutter is open
The camera moves while the shutter is open
Depth Of Field is too shallow
Unless its just technical or hardware you will need to visit a technician. or replace the Shutter.
Try setting the shutter to B and see if you can trip the shutter. If no go then it has mechanical problem. If it works on B but not on other shutter speeds, you have electronic problems.
i have a hp photosmart m525 and the shutter wont open i am able to reveiw my pictures but am unable to take any pictures is there anything i can do about it?
Hi , check everything set c amera speed to 60/seconds auto or manual / check also the the camera shutter blade , open the lense and close to activate the shutter blade .
F4 has an electronic shutter so check batteries ( see enclosed image ). If your batteries are fresh but still no power ( see if display comes on in view finder ) clean contacts in the battery holder. If still no joy camera should go in.
