Sony DCR-HC26 Mini DV Digital Camcorder Logo
A
Anonymous Posted on May 24, 2014
Touch screen of sony handycam dcr hc26 has stopped working
5 Related Answers
Anonymous
  • 10594 Answers
  • Posted on Sep 20, 2009
SOURCE: LCD screen not working on my Sony handycam dcr
Usually there is flexible wire between lcd board and main board of camcorder that got broken and resulted lcd does not work.
You need to replace that flexible wire by qualified camera tech.
Thanks.
Anonymous
  • 3 Answers
  • Posted on Nov 30, 2009
SOURCE: buttons on touch panel of my DCR-HC21 Sony stopped working.
I have a sony handycam dcr-hc30 and the buttons on the touch screen stop working ....any solution to this problem
Anonymous
  • Posted on Jul 02, 2010
SOURCE: My sony DCR-HC26 TOUCH SCREEN NOT WORKING
it's not exactly the same, but this website shows a pretty foolproof way on how to fix it on a different camera.
http://www.agoraquest.com/viewtopic.php?topic=33427&forum=32&start=10&select_page_number=2
i fixed the touchscreen on my hc26 with it on the first try. i put a piece of paper folded a couple times under the ribbon cable connections where it meets the screen (against the plastic frame for the screen, under the blue cable), and put a piece of cardboard against the circuit board to give it more pressure from that side. works like a charm!
Anonymous
  • 95 Answers
  • Posted on Oct 03, 2010
SOURCE: My SONY HANDYCAM DCR-HC26 touch
Most likely, the flex cable that runs from your LCD to your main PCboard is bad. The only thing that you can try to do is flip your LCD around and against the camera. See if the touch screen will work then. The camcorder will still need to be repaired by an experienced technician at some point.
Hope this helps.
www.austintelstarservices.com
Anonymous
  • 15 Answers
  • Posted on Dec 30, 2010
SOURCE: sony dcr-hc26 touch screen does
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
dcrhc26%20reset%20button.jpgdcrhc26%20reset%20button.jpgmoz-screenshot.pngmoz-screenshot-1.pngrsshajan_3.jpg
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Repair handycam touchscreen
It should be the first screen you see when you turn it on, if it has not been set. This is an old camera, so the internal rechargeable battery that saves this info may be dead.
here is the manual in pdf if you don't already have it.
https://docs.sony.com/release/DCR-HC26_Instruction_Manual%5B1%5D.pdf
2helpful
My sony handycam DCR-HC26 is frozen on "clock
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body or the LCD module itself and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
9helpful
2answers
Sony dcr-hc26 touch screen does not work
My SONY HANDYCAM DCR-HC26 touch panel is not working n m unable to forward,rewind,play,or do anything...how do i fix this problem..plzz help..its urgent...
Hope this helps.
6helpful
2answers
20helpful
2answers
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
3helpful
2answers
LCD screen not working on my Sony handycam dcr hc26
Thanks.
3answers
Sony Handycam DCR-HC26
don't expect any help from sony, they are too lazy to take the time, i'll never buy sony again
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
