Cannot understand manual on how to set on/off timer on Kenmore 50 pint dehumidifier
SOURCE: What is the proper humidity control % setting?
It is recommended that your settings stay at 35%. The ideal level of humidity in your house is anywhere between 30% to 60% depending on the weather outside.. I hope that this works for you. Have a good day
SOURCE: I need a manual for the Kenmore #54701
Here is a link for the manual. You can download it and save it or print it.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0406271.pdf
Hope this helps, it's from www.managemyhome.com
Maryanne
SOURCE: my kenmore 50 pint dehumidifier 54501 runs but it
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The
'coil' (a finned metal part that needs air to flow across its surface) may be filled
with dust and obstructions, so no air can move...then no water. There is a
blower motor that must move the air. If it is seized up and not blowing
air...very little or no water. The compressor creates condensation from
air moving across the coil (like the moisture than forms on an ice filled
glass on a humid day) to extract the water from the air. If it's not
working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not
working. If it's real hot air, and the humidifier keeps cycling on and
off quickly, the coil is dirty. Those are the 3 things that need to be
working.
SOURCE: I have a Kenmore 580.53701300 dehumidifier (70
Jim,
I have this dehumidifier and the owner's and parts manuals to go with it.
I will scan them and email them to you.
Hope this helps!
Jamie
SOURCE: I have a Kenmore 50 pint dehumidifier Model 580.54501400
It looks like it is simple to get the filter out but we are finding it to be imposible. How can we take it out. It doesn't just pull down.
