SOURCE: Need a document feeder for 4990 scanner
I don't believe it is possible to add a paper feed to this scanner. The only hopper fed scanner of which I'm aware is the Kodak s1220.
Jeff Underwood
1Scan.co.uk
SOURCE: How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
SOURCE: how to clean the Epson Perfection 4990
I joined a free users group on Yahoo and downloaded the rememdy.
SOURCE: I have an Epson Perfection 4990 scanner on my iMac
You can get the drivers for the Epson Perfection 4990 scanner for MAC from here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=50666&prodoid=49164280&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=28&y=9
And here is the MAC Leopard support page for this device as well:
http://www.epson.com/cgi-bin/Store/support/SupportSnowLeopard.jsp?BV_UseBVCookie=yes
Regards,
Chris
