SOURCE: NEED DEFAULT PASSWORD FOR SMT-190DN SYSTEM BY
unplug the computer and plug it back in.
try password factory setting password 4321.
make sure you push the "STOP" button on your remote first
SOURCE: forgot password to Samsung SMT-190DN
Hold the remote control's STOP ( ) button for
longer than 5 seconds. “INITIAL” appears on the display and
all settings will return to the default values.
• Press the POWER button.
Using the RESET function will erase all stored settings.
Do not use this unless necessary.
SOURCE: how do I reset a SMT-190DN samsung security system
Just talked to Samsung regarding Reset procedure. Simple: Press CH2 and Alarm buttons on receiver at same time for 10 seconds. It will reset to factory.
SOURCE: forgot password for smt 190 dn
Press CH2 and Alarm buttons on monitor at same time and hold for a few seconds...goes to factory reset.
SOURCE: Purchased the Samsung SMT-190DN a year ago and
This seems to happen to a lot of then Either the Inverter Board is bad or the power supply board is bad. Good luck getting it fixed. Samsung seems not to even think they made them.
I emailed all over trying to get mine fixed with no luck. Do you mean the 7 day of recording,this will record til the day you turned it off YES!! even with the screen black it records DO THIS!!!
First... On the back of the monitor look for VIDEO OUT Its down near the Camera wires
Do you have a set of VIDEO and AUDIO cables there red, white,&yellow????
Get a 19'' tv with video and audio INPUTs NOW!! with the RED cable hook it to the Monitor Video out and the other red end to the tv Video in Just the RED ONE don't worry about white or yellow.
NOW turn the Security Monitor ON , NOW the TV let them warm up The tv must be in Video1 or
Video 2 ---NOW YOU SHOULD SEE THE CAMERA's or the screen POINT the remote at the monitor to do things like menu, search. Sorry I'm not to good at explaining things THIS Should work GOOD LUCK
