Computers & Internet Logo
A
Anonymous Posted on May 23, 2014
How do I set a static route lan side on a tew-733gr
stephen Adams
Level 3:
  • Trendnet Master 2,219 Answers
  • Posted on Jan 23, 2015
stephen Adams
Trendnet Master
Level 3:
Answers
2219
Questions
0
Helped
355086
Points
22262
You need to download the user guide from here
TRENDnet Support
Basically
1. Make the computer or network device (for which you are establishing a DMZ link) has a static IP address (or you can use the DHCP reservation feature to ensure the device has a fixed IP address) (see "Set up DHCP reservation" on page 29).
A. Signing up for a Dynamic DNS service (outlined in the DDNS section) will provide identification of the router's network from the Internet.
2. Log into your router management page (see "Access your router management page" on page 22).
3. Click on Access, and click on Firewall & DMZ.
how do I set a static route lan side on a tew-733g - 24492585-jbe4ik0w3n2netaaqjxl1dxw-3-0.jpg
4. Next to DMZ Enable, click Enabled.
5. Next to DMZ Host IP, enter the IP address you assigned to the computer or network device to expose to the Internet.
6. To save changes, click Save Settings.
3 Related Answers
Anonymous
  • 35 Answers
  • Posted on Aug 13, 2008
SOURCE: Cannot connect with SonicWall VPN Client with GigaFast EE420 R
sonic is sitting on the gateway. so dont matter where u are still u cant get outside
Anonymous
  • 1768 Answers
  • Posted on Apr 21, 2010
SOURCE: Route multiple static WAN IP's to LAN IP's
the router has to be set up as a "pass through" device if your ISP has given you a static address pack.
Jin
  • 20 Answers
  • Posted on Apr 11, 2014
SOURCE: Static route for two different subnets
You did not say where are your two computers. Anyway, computers should work on most subnets routes except between 10.20.30.0 and 10.20.40.0 subnet.
Static routing should be set on two computers not on routers.
Assume computer A is connected to 10.20.30.252 Router A and Computer B is connected to router B.
On Computer A, you need to add route to -inet 10.20.40.0/24 via GW 203.187.106.147, and on computer B to set rotue to -inet 10.20.30/24via GW 203.187.106.138. That is all you need.
tip
Show Routing Table button will open a chart displaying how data is routed...
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
STATIC ROUTING:
192.168.2.2 192.168.1.2
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
192.168.3.1 192.168.2.1 192.168.1.1
ROUTER A: Gateway Mode ROUTER C: Router Mode
1STENTRY 1ST ENTRY
DESIP: 192.168.2.0 DES IP: 192.168.2.0
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.2.2
HOP COUNT: 2 HOP COUNT: 3
INTERFACE: LAN INTERFACE: WAN
2NDENTRY 2ND ENTRY
DESIP: 192.168.3.0 DES IP: 192.168.1.0
SM: 24 SM: 24
HOP COUNT: 3 HOP COUNT: 2
ROUTER B: Router Mode
1STENTRY
DESIP: 192.168.1.0 WAN IP: 192.168.1.2
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.1.1
HOP COUNT: 2 DNS: DNS of 1st router
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Apr 22, 2010 • Computers & Internet
tip
HOW TO CONFIGURE STATIC ROUTING ON LINKSYS ROUTER
STATIC ROUTING:
1STENTRY 1ST ENTRY
SM: 24 SM: 24
2NDENTRY 2ND ENTRY
SM: 24 SM: 24
1STENTRY
SM: 24 SM: 24
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
Use Static Routing
Select Entry
Hop Count = 1 + n
Hello Friends! I have a strange problem, I cannot connect to my Office LAN (DHCP) when I am connected to internet (DHCP) via any other source like 3G. Any solution?
I think problem in router table. Your default route set to internet not to LAN. In this situation best solution for you is set up Static IP for your LAN connection, if your netadmin not monster.
Wan and All LAN led bulbs are continuously on- Router not working
Straighten a Norwegian paper-clip, and insert one end into the small hole in the back of the router, to "reset" the router to its "factory" settings.
Or, spend $50, and replace the router.
2helpful
3answers
How to configure static route between 2 LANs?
the command what you have given is correct as per your explanation. If you could post the configuration, it will be good to fix the issue.
1helpful
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Routing problem
I don't know if this will help because I don't see what you and seeing but here is an idea: In every routing scenario I have experienced, you must specify a default gateway with a specific IP address. 0.0.0.0 only points to the device itself, not the other WANS. The gateway IP addresses should be statically assigned. If there is DHCP involved, insure that the gateway address is not part of the DHCP scope but in an excluded range of reserved addresses. For SMTP to work the gateways (and you should have 2 or 3) must be properly configured and TCP port 25 enabled.
Top Trendnet Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
