Microwave Ovens Logo
A
Anonymous Posted on May 23, 2014
What does is mean when your geepas electronic cooking hardware is saying E1
E-1 error on my microwave
Take your pick on the MAKE! Google search query on this is
make model error E1
Samsung microwave error codes
https://www.samsung.com > support > TSG01110365
A reference list of microwave error and information codes for Samsung microwaves. ... Close Menu. Open Search Layer; Cart Number of Products : 1; Sign In. Sign In / Create Account · Why ... Unplug the microwave or turn it off at the circuit breaker. If it's possible that ... E-04. Cooking Time Setting Over Error (Convection) ...
How to fix SE Error, 5E error, and E1 Error Fix - YouTube
https://www.youtube.com > watch
5:13 Understanding E1 error, 5E error or SE error. ... Your browser can't play this video. ... SE error ...
Oct. 30, 2018 · Uploaded by Technoo Lab
Can you please assist with Breville mode LMO530 Error E-1 ...
https://www.justanswer.com > ... > Appliance Repair
Nov. 20, 2020 - Yes, this is a system protection fault. The components attached to the main board are checked by the main board when a microwave is in use. 1 answer · Top answer: Thank you! Have a great weekend.
Oyster microwave error code E1 - Fixya
https://www.fixya.com > Forum > Microwave Ovens
Jan. 8, 2018 - No E1 error codes shown for this model of microwave! Have you checked your manual! Oct 7, 2014 GE JES636WK 700 Watts Microwave Oven. 1 ... Hotpoint JE740WY/GY Microwave Oven "Error code e1 ...
Nov. 23, 2019
E1 fault Samsung microwave CE1113f What to do
Aug. 17, 2018
How do I fix error EA1 code on my samsung microwave
Sep. 28, 2014
Oster Microwave E1 error
Mar. 6, 2018
More results from www.fixya.com
F2E1 - Error Code - Over-the-Range Microwave - Product ...
https://producthelp.whirlpool.com > ... > Starts with F2
Apr. 30, 2021 - There may be a problem with the User Interface / Keypad or the associated wiring. Power unit down by turning off the circuit breaker(s) for one (1) ...
tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
Panasonic NN 9853 Microwave. Won't cook on Microwave but shows H97 in screen. What does this mean?
The code probably indicates a problem with the inverter board. The board can be tested, but the test procedure requires some knowledge of electronics.
Go here for instructions:
http://educypedia.karadimov.info/library/Inverter.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
1helpful
Our microwave, a Summit OTR 24 (built in cabinet with venting), will tend to shut itself down if we cook something longer than, say, 8 minutes straight. No power, lights on panel out. Then a few...
Sounds like the electronics overheated. You'd have to pull it and examine the insides to see what has gone bad. It could be pretty much anything.
Cannot open door to panasonic microwave
I want telephone number and location of geepas emergency light servicer center
Error code E1
this type of code normally mean Control Board Problem. You must call to the profesional repairmain. However you can do the following :
Enter the Service Test Mode as follows:
1. Open door.
2. Press DELETE.
3. Press pads 1, 3, 5, 7.
4. Close door.
5. Press DELETE within 15 seconds (Pressing RESET at any time will cancel the Service Test)
What does E1-F1 mean on your Kenmore
Electronic control has shorted you will need to replace. Usually most times when you see an F1 code that directly refers to the control board. If you have any further questions message me back Thanks Rick
2helpful
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • 1helpful
    What does error message F5 mean?
    There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing..
    I'm not finding the one for for this model online.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    If it's a convection model, F5 would be a damper door sensing error, which is usually a bad switch.
    More info on switches is here.
    One of the damper-related components, either the switch or motor or the damper door may be binding.
    The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
    If it's not a convection model, F5 is probably a sensor error.
    On some models, "SENSOR ERROR" appears on the display when:
    • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
    • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
    Here's some info from Samsung, which is the actual manufacturer of these ovens:
    "Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
    "Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
    "If the message is either ERROR or E-6, it indicates a mechanical fault.
    "For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
    Feel free to contact me directly if you need more help.
    Top KitchenAid Microwave Ovens Experts
    ZJ Limited
    ZJ Limited
    john h
    Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
