I have a LA46A650A1 LCD tv, whenever I connect the component video input of the the TV my DVD Component output or DTH (Big TV) component video output the picture disappears whenever there are 'high brightness pictures' specially in advertisements etc. I am using very high quality gold plated component video cables. I have also tried with different cables with the same result.
SOURCE: "Input" button doesn't work
hi first of all it is not OUR Product this sites purpose is to Find a solution to a Product with problems we wish to help with your problem! there are some products wich the remote cannot work with you havent signed wuch model you want to control so this is my guess try this remote control code finder: http://remotefinder.rca.com/ enter the unit you need and hopefully it will work if the problem is in the "input" button itself then: 1) open the remote - screws 2) clean the surfaces and check for good connection 3) close good luck
SOURCE: Input button
Read further into the manual. If I recall correctly, you have to program the input button seperately. If not, it possibly isn't supported (not uncommon at all, but annoying for sure).
SOURCE: RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
SOURCE: RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
SOURCE: Need code for Emerson TV,DVD,VCR Combo
You may be able to get the codes here free:
http://www.replacementremotes.com/tvcodes/index.html
