Master
- Posted on May 24, 2014
Re: How do i fix a noisy range hood?
IT THE NOISE COMING FROM THE FAN RUNNING? IF IT IS YOU NEED TO CHECK THE SCREW THAT ;ATTACHES THE FAN BLADES TO THE SHAFT. IT COULD BE LOOSE. ALSO CHECK THE SHAFT TO SEE IF IT IS WORN AND MOVES FROM SIDE TO SIDE. IF IT DOES YOU WILL NEED TO REPLACE THE MOTOR.
